My Bad Boy ATV Experience
Old 08-20-2016, 01:22 PM
10 Ringer's Avatar
Default My Bad Boy ATV Experience
I have just now joined this forum, in hopes of getting some help/advice on my situation, as well to inform others and learn more about ATV's and purchase recomendations. We bought a new 2016 Bad Boy Buggy Ambush Is in December and these are the problems we have had with it. The company or dealer isn't being any help.
On the 1st night that the dealer delivered it the buggy wouldn’t crank/turn over in gas mode. The next day another member in our club helped us get it to crank by jiggling wires and filters.
2nd day we took it down one of our club trails in electric and it would not crank in gas to be put into 4wd. It later would not go forward or backward in electric which left us stranded for about 15 minutes while we turned the switch and buttons on and off, jiggled wires,etc.
3rd day We took it to the Eastern section of our property down a logging road which is all electric to go hunting that evening. Upon us getting back to the buggy at nightfall, the buggy would not move in electric so we had use gas while we discovered that we did not have any headlight. Therefore, we had to drive approximately 5 miles back to camp with a flashlight. The rest of the season we had to travel using a flashlight and auxiliary lights to travel, and we didn’t feel comfortable traveling far from camp.
The next day the parking brake came loose so we had to take it to our dealer. When we took it to our dealer, he said that we shouldn’t use the parking brake unless we were on a steep hill. We had to adjust the parking brake handle twice afterwards ourselves and then adjust the rear parking break caliper cable.
2 weeks later we found out why the gas wasn’t wanting to crank/turn over sometimes. We found a disconnected plug going from the switch to the starter. We reconnected it and it started up in gas. In late January, we took it to our dealer to have him fix the headlights. He had to replace a 48-volt converter, and which fixed the headlights, taillights, and 12-volt outlet.
We brought it back home to North Ga from South Ga and the next problem we had was when we were driving it around at home and the front right cv shaft started popping. When we turned to go around a curve it blew out of the boot and we almost flipped, with grease and ball bearings falling everywhere. It would not go anywhere in electric, so we drove it up on the trailer. When we told Bad Boy Buggies and our dealer whom we purchased it from that it broke, they told us to take it to our nearby dealer and they would fix it. We took it to. They said it would be 1.5 to 2 weeks before they could get around to looking at it, which we were fine with. They ended up ordering the front right cv shaft and strut assembly and it took them 2 months before they got it fixed so we could pick it up. When we got it back we noticed that it was leaning to the left on the back side and the front right strut assembly was higher than the left side. We took it off the trailer and then the front right cv shaft blew out again. When we jacked the front end up, we realized that while the wheel was connected to the body, there wasn’t anything to prevent the tire from rotating side to side.
As we loaded it on our trailer, we discovered that we didn’t have any normal foot brakes. We then drove 200 miles to take it to our original dealer (which said that he would fix the brakes, cv joint, strut assembly, and measure where the buggy was leaning to the left and where the right strut was higher than the left one. When we got it back two weeks later he said that he fixed everything, and that there wasn’t anything wrong with the brakes except that there was a little bit too much fluid even though we never added any. He said that he measured the buggy and everything was level. We took it to our hunting club 70 miles away, and when we went to take it off the trailer, it didn’t have any brakes and it rolled backwards off the trailer. When we called the dealer the next day, he said that everything was working when it left his place and suggested that we bled the brakes and check the fluid. We did that and they were working fine, and we went riding down one of our club roads and didn’t have any brakes which caused us to loose control and nearly flip when we had to dodge a tree, while we ran into a briar patch. We topped the fluid level back off and brakes started working intermittently. Now the cart is leaning to the left and the left hand front cv boot is ripped apart and the right front cv joint is popping again. We brought it back to North Ga and parked it in our storage building. We then measured the front side and the strut on the right is 2 inches taller than the left hand side even though the tire on the right side 1-2 inches lower on the right side.
Since it first arrived we have noticed that the front cv joints/axles are at an angle whereas our other members’ same year model and make bad boy buggies as well as the one at Bass Pro Shops goes straight out from the motor to the wheel. Ever since the first month we have tried to get Bad Boy Buggies and our dealer () to buy it back because it is a lemon. Bad Boy Buggies says that the dealer would be responsible for giving us a refund. Our dealer said that Bad Boy Buggies would be responsible for refunding our money. All they will ever say is that they can fix it if we take it to them. We have had so many breakdowns that we decided to buy a $80 technicians/service repair manual. It has been broken down for over 4 months and this is will just be month 7 of us owning it. It has had us scared to death that we would get in the woods and leave us stranded. It has always been very tippy and it seems prone to want to roll over. It will only go 10 miles on a charge our hunting land. What would you do or have any past experience with anything similar to this. I hate having a one ton 15k paperweight sitting in my garage.
Disclaimer: This is MY experience, dealing with the dealers and people that we have. This is MY Bad Boy Buggy that I own. Yours may not give you any problems and may be the best hunting vehicle you have ever had, but this is to inform others of MY experience. Have a blessed day, 10 Ringer
Old 08-20-2016, 01:32 PM
Kymco 450i's Avatar
Should have taken it back to the dealer on the 5th day and demanded a refund or stop the payments.
Old 08-20-2016, 01:43 PM
10 Ringer's Avatar
We did ask and then later demanded a refund and the dealer says that he couldn't do it (he just didn't want to) and it would be the manufacture's responsibility to give us a refund. The worse part about it is the dealer has been our friend on our hunting club for the past 8 years.
Old 08-20-2016, 01:49 PM
user493's Avatar
Moto Psycho
I would have asked for my money back after 2-3 days of that crap. I think you need to get a lawyer and sue the dealer and the company. You also need to find out what kind of lemon laws you have in your state. I'm guessing it's too late to get your money back. Whatever you do keep us posted.
Old 08-20-2016, 02:43 PM
10 Ringer's Avatar
Thanks, jumbofrank. The Ga lemon law doesn't cover ATV's, but the federal lemon law or Magnuson Moss Warranty Act does. We are trying to comply with the company as we are taking it to their plant in Augusta this next weekend. They said they are going to go over it with a "fine tooth comb" but do not say what they are going to do. We are trying to save a lawyer as last resort because the dealer has been one of our good buddies () on our hunting club for the past 8 years. We would hate to stir that up with a stick and ruin a friendship, as if it's not already hurt us enough. I'll keep y'all posted.
Old 08-20-2016, 03:52 PM
Kymco 450i's Avatar
Boy you have a tough one on your plate. Not sure I could consider him a friend any longer if he couldn't step up to the plate and make things happen with the factory. Hopefully the factory will do the right thing but if you continue to have problems please keep us posted. Those things are expensive, one of the more expensive units on the market so there is no recall for this type of treatment.
Old 08-20-2016, 05:13 PM
Seems like it's kind of a one-sided friendship there. If I had a dealership and a friend of mine bought a unit that quickly shows itself to be a lemon, I'd try to fix it. If that didn't work I would feel compelled to give a complete refund. I wouldn't be willing to let my reputation or friendship be tarnished by this kind of incident.
Old 08-21-2016, 10:43 AM
Zrock's Avatar
Super Quad Patrol
The dealer/ so called friend is taking advantage of that friendship. He should have been on the phone with the manufacturer long ago arranging to get you a refund or new buggy. It also sounds like he is not even doing the repairs properly.. Does a friend take chances with your life like that?
On a side note what is the theory on a gas/electric rig? To me that is way to much weight to get around in the back country..
Old 08-21-2016, 12:55 PM
greg74's Avatar
The main point here is that the machine is complete junk, regardless of whether the dealer is a friend or not. Anything that new that has that many mechanical failures was obviously defective as soon at it was assembled. The lemon law should take over and you either get a new unit or get all your money back. If I had that many problems, I would opt for the 2nd option and take my money and buy something else.
Old 08-21-2016, 03:14 PM
The idea behind the electric motor with the UTV's was stealth. Almost no noise compared to a gas model. Could get into your hunting area and close to your stand without waking up the neighborhood. The idea with the gas was so people with the electric machines could get back to civilization when the battery ran out and use the gas in situations requiring low gear that would run the batteries down quickly. Not a bad way to do it, on paper...
Quick Reply: My Bad Boy ATV Experience
