2005 polaris phoenix
Three things I can think of to check off hand. Since it's not displaying neutral,check the gear position switch connector coming from the gear case, the left control brake switch(If I remember correctly it's a starter lock out switch also like the youth models) plus the starter relay under the seat area. Probably one of these.
I am no where near a atv troubleshooter but while digging around the only way it attempts to turn over is with a jump from my truck but it doesn't fire. I checked the relay fuse which was burnt and installed a new one. I also noticed no spark from the spark plug so I bought a new one and that also isn't working. It has to be something near the start button/over ride area on the left hand grip just don't know how to check
I certainly can't remember everything on this little 200 from almost 11 years ago,that's why they make manuals just for people like me.. Before I started jumping off with a truck battery again that could really cause problems,I'd spring for this cheap 5 buck manual that can hep you trace down the problem.2005 Polaris Phoenix 200 Service Manual PDF Download
KJR
09-29-2016 10:22 AM
