2012 Sportsman 550 XP trouble
Or simply the T-map sensor. Usually when this happens you can have a wiring short in the connector or harness. Wires can be chaffed/bare or wires can feel soft and melted internally. One place has good repair kits if needed.https://otbpowersports.com/product/t...epair-harness/
Another area that can cause problems is the rubber grommet under the T-bap. They can split and suck air. It's located on the intake manifold.Item #6.Sensors them selves are rarely the problem. Mainly the connector and wiring harness or the grommet.
