2008 Polaris sportsman 500
Load test the battery. I've had brand new ones out of the box that would show full 12.8 volts but had a dead cell and didn't have enough amperage(current)under load to start an atv. Look at this article.https://www.batterystuff.com/blog/ho...ry-is-bad.html Plus 13.6 volts is on the low end of the spectrum as far as the regulator keeping a battery charged. Running lights,auxiliary equipment,etc can use more voltage than being supplied to the battery and may not supply enough to keep the battery fully charged also.Normal rate is between 14-14.5 volts
