Four wheeler shutting off around sharp right turns
How does it go from being a Predator 500 to a Predator 90 It does have a cdi as do all machines but in your case on this little one,check the throttle cable for binding side to side and also any wiring that could be shorting out or not securely connected under the front cover as you make sharp turns.Plus do you have any thing on the key fob? Any straps,key chains can cause the ignition switch to move slightly and kill the machine.
#16
#17
#18
#19
that is interesting cause that was the first time I had the paracord on the key that it did that. Can you see that the key actually moved or can you not even tell?
#20
I couldn't really see that the key moved but it moved a little bit. It was halfway off and halfway on.
