Looking For Info On SKS Rifle
I was out looking at rifles today, and i came across an SKS rifle, it also has a bayonet on it. I don`t know anything about these rifles at all, so im hoping some of you guy can help me out. Is this a good quality made rifle ?, they wanted 399.00 dollars for it, is that a good price ?. Any information you guys can give me will help. I am thinking about buying it.
It's a little high but SKS rifles are getting up there in price compared to what they used to be. I generally won't pick up a used SKS if it's over 200 bucks.
They're a rugged and reliable rifle but at 400 bucks I'd save my money and get an AK-47 or AK-74 for a few dollars more. More versatile, detachable magazines etc.
I had typed up this long reply with lots of info, then tried to spell check it and got it all erased so to hell with it. LOL. Good rifle, but for $400 it should have a nice scope and/or upgraded stock. The bayonet suggests to me that it's still rocking the original stock and in this case original isn't better since the sks stocks sucked. There's tons of aftermarket for these, and they are a great rifle. Does it have the SKS or AK-47 receiver? You can tell by looking at the clip. If it has a long extension off the front of the clip at the top then it's an SKS receiver. I don't remember if mine was special ordered with the AK receiver or if all the Chinese issue ones have it, but it solves the only major difference between the AK and SKS.
At that price it better be a Russian SKS. They have threaded barrels instead of pinned and the stock is usually laminate wood. There was a paratrooper model that accepted AK-47 mags. Now mostly all you will see are yugos and they should be between 200 and 300 new. I checked ebang.com to see what they were selling for and most of the ones over 300 had no bids unless they were a special model or Russian.
I've had an sks for twenty years and have gotten deer with it. When I got it, I was told to be sure and get one made with machined parts. Most of those available at that time were made with stamped parts. I think you could tell the difference with a close look. A friend of mine who was in Viet Nam told me a story about his platoon slogging across a rice paddy when they come upon the rotting body of a viet cong. Laying in the mud nearby was an sks. One of the guys rinsed the mud out of it, pointed it skyward and pulled the trigger. It fired.
the SKS is the 2nd best Commie weapon on the planet in the semi category, the AK-47 is #1 semi or full auto...Ive owned one for no less then 20 years myself
some thing to look for in a SKS,
first thing to look for is a Blade bayonet, this will be a older weapon with a screwed in barrel, the spike bayonets are a newer gun and have a pressed barrel & can not be Grand-fathered....not as good as threaded.
they have a double Gas Chamber recoil that after a few 1000 rounds will carbon up and should be cleaned, most people do not notice they have a cleaning kit in the stock of the gun it's a round trap door on the butt stock, to clean the Stainless Steel sleeved barrel
you can remove the stock 10 shot mag and use a 30 round detachable one, and right out of the crate, like was posted above my gun was dunked in Cosmolene VERY HOT water will remove a lot of it
and last but not least these weapons are nail drivers in the right hands & was used to guard Stalin's grave up unto.....5-10 years ago, if you look for footage of his grave the soldiers are carrying SKS's.......I know some of this info is redundant out dated and boring but for reliability & accuracy as I said when I started only one other Commie gun ever built that will out do it and that's the AK-47.
Note: anything posted in this post should be researched for accuracy......but most if not all is dead on!
PS: yea I was bored
PS: yea I was bored
PS: yea I was bored
PS: yea I was bored
The Russians started producing the SKS in 1949, and the first Russian SKS`s made used a spike bayonet. From 1950 on the Russians changed over to the blade bayonet and us it from then on while producing the SKS.
The Russians gave the SKS tooling to the Chinese and in 1956 the Chinese started producing there own SKS`s and they originally used a blade bayonet, but sometime after 1956 they changed over to a spike bayonet and used it until the end of production.
No SKS has a double gas chamber, they use a gas piston, with a short piston extension behind the main gas piston that pushes on the bolt.
The barrels are not stainless steel sleeved, they are chrome lined.
The SKS comes with a fixed ten round magazine, you can get larger 20-30 round magazines, but there all junk and you will have to deal with feed jam problems.
If you get an SKS thats covered in cosmoline, the best way to remove it from the metal is to remove the stock and get a container and fill it with mineral spirits and use a paint brush to clean all the metal parts.
I have six SKS`s, three Chinese, two Russian, and one Yugo. They are all very good, very well made rifles, and there fun to collect and shoot.
About half of the information you gave on the SKS is wrong.
The Russians gave the SKS tooling to the Chinese and in 1956 the Chinese started producing there own SKS`s and they originally used a blade bayonet, (the older models I was referring to) but sometime after 1956 they changed over to a spike bayonet and used it until the end of production.
No SKS has a double gas chamber, they use a gas piston, with a short piston extension behind the main gas piston that pushes on the bolt. same thing to me, yes it is 2 pistons but yet still a chamber also
The barrels are not stainless steel sleeved, they are chrome lined. Agreed typed in the wrong word
The SKS comes with a fixed ten round magazine, you can get larger 20-30 round magazines, but there all junk and you will have to deal with feed jam problems. Depends on what brand you use..Ive bought some realy crappy ones, others work like Stock
If you get an SKS thats covered in cosmoline, the best way to remove it from the metal is to remove the stock and get a container and fill it with mineral spirits and use a paint brush to clean all the metal parts. this is a personal preference for either one of us, as long as it comes off and you thoroughly clean the weapon its apples and oranges!
how you feel about the accuracy of the SKS?
