Pic help
Pic help
Try this...........
1 right click on you picture and select open with Paint or Microsoft Paint
2 under the images tab if you click attributes it will tell you how big your picture is now (needs to be
750x750 or under, try and get it as close as possible so the pic is good size)
3 under the images tab click on stretch and skew
4 change the horizontal & vertical to 60% and click ok (60% is good to start off with, you may have to
try different combinations. I always click Edit undo if its not then try again with a different number)
5 under the images tab if you click attributes it will tell you how big your picture is now
6 save your picture as a .jpg file (.jpg will have a small file size) into an easly accessed folder
7 try uploading again to your page.
you may have to make them smaller than 750 to get the size below 150kb
once you have your page done click the post bio button
