gearbox leak
gearbox leak
I have a Dingo150 that is leaking gear oil. The drain plug is tight and not leaking from there. It appears to be leaking on the side opposite the site glass. I don't see any bolts that look like they will tighten the thin plate and gasket on the side. Does any one know if there is a common problem with this model or know how to fix this leak?
Thanks
Thanks
exmotocrosser
09-13-2019 06:12 AM
