Chinese atv
Pull the fuel line from the carb and see if it's getting fuel. If it is,you might try cleaning the carb,but I'd do a compression check first. Most of the blamed electric chokes never worked right to begin with,but you can disconnect it. If it's like a lot of these carbs with auto chokes you can start them easier by blocking off the air inlet with your thumb or hand on first crank up. This allows more fuel less air and what most of these little ones need to crank.
