Honda Side by Sides Talk about the resilient Honda Sport and Utility.
1985 250es big red not shiftin right help,please
Old 05-17-2010, 09:19 AM
leonard911's Avatar
Default 1985 250es big red not shiftin right help,please
i just bought a 1985 250 big red that has some problems shifting down for second to first. im driving along and im gearing down to slow down and i try to go from second to first. i push the shifter down the whole way and i fell no click but it comes back up fine and is stil in second gear. i have to push down on the shift a lot of times before it goes from second to first and somtime this problem happens even if i'm stopped,, does anyone know what this might be,, thanks
Old 06-26-2010, 09:42 PM
honda200s's Avatar
Default honda big red not shifting right
There is an adjuster on the right hand side of the wheeler if you are sitting on it, that might help if you adjust it you need a 14mm wrench and a regular screwdriver, loosen that nut and turn that screw one way and see if that helps
Old 07-19-2010, 11:42 AM
bigger redder's Avatar
if that doesn't work maybe direct your question to 3wheelerworld.com they have so really good tech. pros over that that are very familiar with this trike.
Wooodyii2
11-16-2020 07:14 PM
Dammar
08-26-2015 07:12 PM
Dustinyoungs
07-24-2015 07:18 AM
CRamshaw777
07-18-2015 05:46 PM
HondaR24
07-16-2015 10:45 AM
Quick Reply: 1985 250es big red not shiftin right help,please
