Honda Side by Sides Talk about the resilient Honda Sport and Utility.
Honda atc 200e
Old 11-16-2013, 12:32 PM
BREKS's Avatar
Default Honda atc 200e
i recently got a 1983 honda 200e. the machine smoked so i changed the oil and the gas i also cleaned the carb. i am assuming it needs rings to fix the smoking issue. My main issue though is when i was running the atc i looked down and saw gas pissing out of the over flow and oil was pouring out from underneath the machine. has anyone else encountered the same problem or have any solutions :S...
http://gyazo.com/d2ed7df0d2f0ad367278eca6a88c6afd
http://gyazo.com/aa30b8bd299af706e70189e325d32bd2
http://gyazo.com/3261d2977ee000a9d9183160d0bc1eba
Old 11-16-2013, 06:47 PM
First thing I'd do is rebuild the carb and go from there.http://www.ebay.com/itm/1982-1983-Honda-ATC200E-BIG-RED-200-CARBURETOR-CARB-KIT-MADE-IN-JAPAN-03-027-/360488277959?pt=Motors_ATV_Parts_Accessories&hash=item53eec697c7&vxp=mtr
Old 11-16-2013, 11:31 PM
BREKS's Avatar
that would fix the gas issue but do you know of any plugs or anything near the back/bottom of the engine where oil may leak?
Old 11-17-2013, 07:28 AM
Been awhile since I've worked on a 3 wheeler,but I'd clean the engine up and check especially around the drain plug and o-ring at the bottom.Dirt Cheap Honda & Arctic Cat OEM Parts & Accessories – Cycle Parts Outlet
Old 11-17-2013, 05:07 PM
BREKS's Avatar
are you talking about the plug that has the oil filter in it. i cant find any other plugs on the machine
Old 11-20-2013, 05:24 PM
BREKS's Avatar
i took the engine out and behind the sprocket when you look from the back of the engine it looks like there is a missing piece of the engine. is there supposed to be a plate or something behind the beside the sprocket
rgjackson
09-17-2015 11:21 AM
wendal
09-15-2015 01:50 PM
wendal
09-15-2015 01:48 PM
stcspiderman
09-13-2015 05:15 PM
Jason Campbell
09-07-2015 02:25 PM
Quick Reply: Honda atc 200e
