SERVICE MANUAL
SERVICE MANUAL
Under the specifications it has the tie-rod ball-joint spacing at 349.5 mm or 13.76 inches. (400 model)
Measure the distance from each locknut to the end of the threads and compare it with the above. If it it's incorrect, loosen the locknut and reposition the locknut and ball-joint on the threads. Position the ball-joint at each end of the tie-rod so the studs face 180-degrees away from each other.
Torque specs- Tie-rod stud nuts and tie-rod locknuts- 40 ft-lbs.
Customer Service #1
05-15-2020 08:46 AM
