recon 250 es shifting problem
My recon is having same shif problems will you let me know when you find out what the problem is or e-mail me so we can discuss this futher thayes@landmarkbuilders.com
Thanks Travis Hayes
Thanks Travis Hayes
The Haynes manual for my Foreman, which is also an ES model gives the following diagnostic codes:
Turn ignition on, then off, then back on
Flashes at gear position indicator::
0 system normal
1 ECU
2 shift switch
3 angle sensor
4 gear position switch
5 ECU motor (defective ECU)
6 ECU failsafe relay
7 ECU voltage converter circuit (defective ECU)
8 angle sensor, control motor or ECU
9 angle sensor or ECU
10 pulse generator
11 speed sensor or ECU
Found this earlier.
Anybody found the locations of the sensor and all the other little suggestions. New to this but my little recon is in need of help before I shoot it.
12 gear position switch or ECU
0 system normal
1 ECU
2 shift switch
3 angle sensor
10 pulse generator
Found this earlier.
My recon was doing the same thing. As I work on it I was wondering how do you keep the water out of electrical connections?
I removed the ECM and cleaned it and cleaned the connections and put it back together and the light stopped blinking and it appears to work fine now. I bet it was caused by water/mud in the connections, so I want to know what you use to keep water out of the connections.
Thanks,
Grady
Thanks,
Grady
