Honda TRX250
#21
Honda TRX250
1.5 turns should be close enough. Any adjustment here will not be enough to be creating your problem. You can always adjust from there but likely outward and not more than 1/2 turn or so.
Did you make sure that fuel running from the tank is good enough? Did you make sure the screen at the shut off is clear? Did you try to run it with the gas cap off in case it is not venting properly?
#22
Honda TRX250
hey guys.. I am 13 years old and i currently have a 250ex..Ive had this quad for about 2 months and i think i should move onto a bigger quad..i just feel the need to get more power.. should i get a jet kit and aftermarket exhaust and do engine work to my 250ex or go for the Z400...I ride in trails butr there pretty wide trails and i sometimes go on the street..So wat do u think i should do???
#23
Honda TRX250
In my opinion, if you're 13 and have only been riding 2 months, it's not time for you to move up to a real sport quad yet. That's why there are so many atv-related deaths in the news all the time. But it's also not worthwhile to mod the 250, there's too many bottlenecks in the design.
#24
Honda TRX250
In reference to: (Did you make sure that fuel running from the tank is good enough? Did you make sure the screen at the shut off is clear? Did you try to run it with the gas cap off in case it is not venting properly? )
I get a good flow of gas when I open the drain screw at the bottom of the carb. so I'm thinking there's no clog on the filter or the line. The gas is brand new, high octane.
I'm heading out now to tear it apart again and hope to have better luck this go around.
Thanks!!
Thanks!!
#25
Honda TRX250
wigglez1014 its thoughts like that can kill you.im 16 and been riding a 300ex for a year and a half now. im not thinking about going up for maybe a year. a 300 is will be to powerful for you a 400 is way too much for a person with that low level of skill. first hard lauch and your back is on the ground and the quad is 50ft infront of you. by my guess by all the 13 yearolds by me you are only 100lbs im 205lbs and my 300 is more power then i can control.had to adjust my clutch to weakin the lauch. a 250ex has about 18hp 300ex have about 28hp 400ex have about 39hp 450r about 49hp. you will be going up 20 or more horsepower and im having a hard time with less then 30.but after all my ride time i have better control of my ride.
#27
Honda TRX250
#29
Honda TRX250
i just cheacked the charts again stock 250ex is about 15hp stock 300ex is about 21hp stock 400ex is about 30hp
you were close on the 250ex nowhere near on the 300ex or 400ex. i had my 300 dynoed and it did between 25-26
its not stock but its far from beating 400s.so i guess what had was the highest possible hp rates sorry they were off by 3-9 hp
