yfz450 or trx450r?
yfz450 or trx450r?
Both are excellent quads but I leaned toward the Yamaha this year.
As far as reliability is concerned, you would be hard pressed to find an engine builder who would say the Honda is the MOSt reliable. If anything, this is the most unreliable engine when riders start skipping on maintanance.
Keep the oil fresh, the air filter clean, and stay on top of valve adjustments and either machine is rock solid.
Wow man, That's a old thread you found there. Could of started a new one. Either one will be find. You couldn't be disappointed either way. Find the best deal and go for it.
go with the new yfz 450r and youll never look back its all around faster than the honda my friend has a trx 450 with a stage two hot cam 13.5 compression piston and a port and polished head and i have never lost to him in the sand dunes. and as for suspension the new 450r is great i love it for jumping and trail its considerably softer than the old style plus a much larger seat for comfort
#15
Youre an idiot!!
Of the two 450's you listed the yfz is the 450 of choice for most people it's the faster/handler of the the two machines, but you said you wanted a trail machine this is where the trx shines in the 450 class it does have a little bitmore low end torque[stock] than the yfz for trail riding. If I were you I would consider a raptor 700r as it is by far more reliable,faster and a better trail machine than any of the 450's. The torque band on the raptor is perfect for slow to fast trail riding!
#17
Even though it's about 5-6 years old now, dodge57hemi made a good point. For regular trail riding (not racing) the raptor is geared better, has more torque, and has a more reliable engine. It's the same mill in the grizzly which has been worry free. Hondas are typically the most reliable in a given class but the raptor isn't in the same class as a 450r. All of the 450s are esentially hot rods from the factory with aggresive cam profiles, titanium valves, more aggressive head porting and higher compression ratios (11:1+). The raptor on the other hand uses SS valves, a smaller cam and only has a 9:1 compression piston from the factory. The fact that the raptor (and most big bores) make there power at a lower and more constant rpm is a huge benefit to the life of engine components. The raptor will still be slighly faster in stock form and You could probably get 2-3 times the life from the top end of a big bore 700 compared to a 450.
#19
That is the most ridiculous attitude I've seen on these forums. Your calling someone stupid based on opinion. Not only that, an opinion from 6 and a half years ago. Nobody asked about "MAXC series" and nobody cares about your "podium finish". It is FACT that the Raptor has more low end torque as was stated. It's your OPINION that it's not good. DODGE57HEMI's suggestion of a 700r would be echo'd by most in these forums. His suggestion was not belligerent in the slightest, in fact I'm curious if you know the meaning because, you sir, are the one being belligerent here.
09-23-2015 06:23 AM
08-05-2015 02:10 AM
