Just got an 05 trx450r and got a question...
<div class="FTQUOTE"><begin quote>Originally posted by: punchout101
you seemed like a smart fellow in some of the posts i saw....so i checked old oil posts and saw your responses on changing oil and types of oil...i saved the post about letting it run out of the weep hole and then running it for a short while and adding 100cc's...i cleaned the air filter and filter box and drained the coolant and replaced it with the honda brand coolant and went and got oil...the guy at the shop i go to told me to use honda hp4 hi performance 4 stroke oil 10w-40 SJ...i have a few questions though...do i fill it to the top mark in the site glass or in the middle of it? How long should i wait to run it after i fill it? And the post you made about pumping the throttle a few times and then using the hot start worked nicely...Thank you very much and anymore advice is greatly appreciated.</end quote></div>
hey- what the heck ? Honda sez never , NEVER , NEVER pump the throttle b4 starting ??
I know what Honda says, but on the 450R if you pump the throttle 3 times before a cold start it starts up right away!
Pump the throttle when it's hot and you'll flood it and be kicking (on an '04 and '05) for quite awhile. Practically run the battery dead on a 450ER
#15
#16
i have a video of me blowing myself...wanna see danny? seems like you would get into something like that...i asked for a tip or something from a wiser man than i on the subject but you come in being the smart *** little 15 year old baby dick that you are...so blow me dan...
08-05-2015 02:10 AM
