Still no brake
Still no brake
Not sure but does the Rancher have Hydrolic brake on rear ? Or is it just machanical brake ?
If it has machanical brake the brake cables maybe bad , this happened to me on an older model Honda TRX350FM 4x4 and had to replce the cables ; the cables on the old 350 had the teflon coating worn off causing the brakes not to work !
But if the rear brake is Hydrolic the wheel cylinder maybe seazedup not allowing the cylinder to spread out the brake shoes , this is the only thing that comes to mind ; hope this is of some help and welcome to the forums !......
Still no brake
Thanks for the info Williebee, mine is the mechanical type. I thought the cam maybe worn out but had not thought about the cable. I'll check or maybe just replace it anyway. Really don't care about rear braking, but I would like to have a working parking brake. Again, thanks. Jim
oliveiracarlos
09-07-2015 03:39 AM
