need help for rubicon
I think the question to ask is if 27's are even necessary. Are the additional .5 inches (or so) of ground clearance going to make or break you on your next riding trip? Why couldn't you go with a nice set of 26's? or even the factory size (25's)? The Rubicons are known for their great stability and handling out on the trail. Going to 27's not only adds unsprung weight (the worst kind of additional weight), and more wear and tear on the tranny and CV joints. It also compromises the handling and stability of the Rubicon. Why spend all that money to wear the bike out faster??
On the other hand, if your main goal is riding through the slop and the mud, by all means knock yourself out. I can see where the larger tires MIGHT help in those cases. Just don't try to take a sharp turn anywhere.
I'd stick with the 27's, the extra inch of ground clearance is well worth it on bikes that are already pretty low. I think highlifter has/had a kit that changes the fender brackets to clear larger tires. You may be able to fab something up or have a shop make up a new mount.
10" wide tires are pretty wide in the front, I'd go with 9's if your looking to trade or swap up. The additional weight of a 27" mud lite is miminal compared to most other brands of 26 or 25" tires in 6 ply. I've run 27" tires on my Foreman for almost 9 years with no CV troubles, tranny troubles at all. I've replaced wheel bearings, but I suspect I'd be replacing them anyway given the amount of mud riding I do...even so that expense isnt great by any means.
I also ride alot of fast hard pack and sometimes paved trails to get to a riding area...my handling and stability has not been comprimised by raising the bike one extra inch in the air (I dont run a lift), with 6 ply sidewalls the tires stay firm in the corners instead of rolling on the bead, my latest tires are Radial and handling is UNMATCHED compared to many other tires I've used and tested.
