400ex airbox help !
400ex airbox help !
I've been having dust in boot between air filter and carb. tried three differant filters with the same results. i'm wondering if the breather vent from crankcase to the boot might have somthing to do with it. hose & boot are good with no weather cracking. hose clamps get tightened. CAN SOMONE PLEASE HELP????
400ex airbox help !
Pull the filter off and hold your hand over the opening. Crank the starter a couple times (kill switch off!), and you should feel a vacuum develop. It should hold for quite a while, but if it doesn't then you have a leak somewhere.....
I highly suggest the ProDesign (ProFlow) adapter and foam air filter, along with the EHS Racing airbox lid with Outerwears!
400ex airbox help !
i had the same problem. the boot between my carb and airbox had a film of dust stuck to the inner walls. and my UNI filter was clean an oiled right before i rode. i did the vacuum check reconranger said and there didnt seem to be a leak anywhere. can someone please tell me what i should do?
400ex airbox help !
You can shut fuel valve off, and then drain the carb (screw at the bottom of float bowl), and that saves you pulling the filter off every time you transport it.
Also, I have used a number of different filter oils over the years, and I keep coming back to both UNI filter oil and cleaner. UNI is less tacky (easier to work with and doesn't gum up the filter) than some other products out there, and it is thin enough that it applies easily. I oil mine up, then let them sit a few days (not on the engine of course) and the excess oil will drain down.
