2001 Rancher Stalling in water
i have a 2001 Rancher ES and when i got into water that is about 2 inches above my foot pegs it stalls out like it is getting water in somewere. i have tried to seal what wireng harnes i can but was woundering if anyone has had a similler problem and what advise you can give me on how to fix it, or what might be wrong which is causeing this because the water is not that deep barley enough to get the bottom part of the motor wet. any one has any input PLEASE help me .Thanks Rick
Thanks i will try that tomarrow,but with the water not even getting near the carb and thoses hoses being just over flows i would not think water could get up in the carb. but maybe somehow it is im going to work on it tomarrow. thanks again, any other idea would be great too.
my rancher did that when one of the vent lines droped down as soon as that hose went underit would die you might try putting di-electric grease on the stator connection also if that bottom"drain" tube check valve is messed up it will let water "suck"up into the bowl on the carb
it really dosent sound like you have an electrical problem
i see the 2 lines coming off the carb but then it T-s into one line going down. i tied that line up plus another line too. i also checked the one way velve today and it is working. i m going riding tomarrow and will see what happens if no luck i will try the di-electric greese. thanks for the input keep it coming.
Customer Service #1
05-15-2020 08:46 AM
