2001 Foreman 450es....shift motor question
Old 09-17-2008, 09:55 AM
250arrrr's Avatar
Default 2001 Foreman 450es....shift motor question
I have just about every forum on this ES stuff and hated posting another one. I tested the shift motor with 12v and it worked up and down. I tried it with a 6v batt. from a lantern and it tried to move but wouldn't move enough to engage into gear. I tried this b/c the motor doesn't get 12v, correct?
Everything else on this quad has been changed out, except the wiring harness. I MEAN EVERYTHING!!! Except the motor too.
I guess the question is, should it work with a direct 6v connection?
Thanx in advance.........Ken
Old 09-17-2008, 07:43 PM
250arrrr's Avatar
Any Help guys/gals ??
Old 09-17-2008, 08:57 PM
HondaMechanic's Avatar
The shift motor operates on 12v ...
Old 09-17-2008, 11:43 PM
250arrrr's Avatar
Thank you. For some reason I thought I read that only 5 - 7 volts was sent to the motor. I don't think I'm getting ANY volts there.??????
Cole Hadden
08-24-2020 11:11 PM
ghost civic
07-19-2015 10:13 AM
ghost civic
07-15-2015 10:48 PM
maxjung
07-14-2015 03:10 AM
Quick Reply: 2001 Foreman 450es....shift motor question
