I need help with a Fly wheel.
The only other flywheel that will fit the 1985-87 TRX250 is 1985-88 ATC250 BigRed or SX .. And there are 2 different makes ( Mitsuba & ND ) and they are different sizes and are NOT innerchangable .. You will have to check the side of your flywheel and see what type you have .. And the only way you can use the other make is if you change both the flywheel and the stator ..
