biggest tires on a rancher 420
i put a set of 25 radial duro powergrip tires on my 420 i lost a little low end power, nothing to realy notice, i will say these radial tires, are performing great, i dont get as much bump in the steer , hitting deep ruts, they glide over logs, i get alot better ride at higher speeds, id take a radial tire anyday over a bias tire.
I dont really want the bigger tires because i know that it will effect the low end power, but if you have 25" tires you get a better selction to choose from than if you keep the stock 24". Also why cant honda just use the same fims sice for the front and the rear?
<div class="FTQUOTE"><begin quote>Originally posted by: wa3rh
i dont think youll notice a big loss in power with 25 inch tires on the 420, i wouldnt put anything bigger then 25 inch. i havent noticed any handling loss with 25,s ive noticed alot better handling with a radial tire.</end quote></div>
My recently installed 25 inch ITP TerraCross radials, no noticeable loss in power, greatly improved handling and ride. Even my cat likes them!
<div class="FTQUOTE"><begin quote>Originally posted by: Tom of Barbaria
sac7000 your wheeler looks really good with those tires, how do they perform, in different terrains</end quote></div>
I've yet to test them in deep mud or snow and since my 420 is 2WD only I tend to stay on the hard trails and forest service roads. The difference in handling and rider confidence is where they really shine.
I noticed the other day when I was visiting the local Yamaha dealer (I needed a mirror) numerous quads and ATV's were sitting on ITP TerraCross radial tires.
