250R BIG PROMBLEM
Old 10-27-2008, 01:20 AM
84 250r's Avatar
Default 250R BIG PROMBLEM
Here is a tuff one for alot of people i cant find any one to figure it out. ok my 84 250r starts first kick idles great i ride it around just fine after alittle while it starts revin really high but it is not the throttle stickin and when it starts to rev high the kill switch wont turn it off we even pulled of the spark plug wire and it still wont kill i got told that it is carbon built up on top of the piston but i cleaned that up and it still does it. it has been sitting for over a year. the intake has a leak in it i thought it was gettin to much air but why wouldnt turn off with the kill switch. if you got any ideas please tell me thanks.
Old 10-27-2008, 12:47 PM
battman's Avatar
You answered your own question, you have a known problem, an intake leak which is causing a lean condition, its getting your engine hot enough to continue to ignite fuel with out the help of the ignition system. you are lucky you have not seized the piston yet. get that intake leak fixed ASAP!
Old 10-27-2008, 01:06 PM
84 250r's Avatar
Thanks man i will get that fixed and see if it helps
Old 11-03-2008, 05:26 PM
ikeyrider's Avatar
Yes a leak in the intake/boot will allow air to lean out the mixture, like battman said get it fixed be4 you ride it again because if it is running without a spark who's to say when the mixture will ignite in the stroke, it could be on its way up.
Old 11-03-2008, 09:20 PM
mojojojo56's Avatar
it diesels in case you didnt understand...
blasters do this too, probably others.
Old 11-04-2008, 10:12 AM
ikeyrider's Avatar
yeah its mainly because they have so much compression, but still very dangerous in a gas engine
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
Traci Carnahan Simmons
08-09-2015 03:00 PM
CRamshaw777
07-18-2015 05:46 PM
Quick Reply: 250R BIG PROMBLEM
