2007 Rancher 420 battery drain - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 12-24-2008, 04:40 PM
Default 2007 Rancher 420 battery drain
I have an 06 Rancher 350 and an 07 Rancher 420. I've never had a single problem with the 06 battery. I've let it sit for months at a time and it always starts right up. I noticed with the 07 if I let it sit for a month or so the battery would drain and I'd need to charge it to get it started. Well now the battery needs to be started with a charger everytime it sits overnight. Is there a problem with the 07 420 having battery drain issues or is it just mine? Does anyone have some troubleshooting advice for me? Can you recommend a good replacement battery? Thanks
Old 12-24-2008, 10:38 PM
cherokee99's Avatar
batterys can be unruley...they might last for years with being started 5-6 times a year. or drain after a week or so. if you have let the battery die alot, sounds like it, then charge it up and it wont last: the battery is probably bad now. they can be tricky things.
i would try chargeing the battery overnight, not connecting it to the atv, and let it sit for a day. then take a volt meter and check the charge. if its less than like 12v its not holding a charge well. a good battery will hold like 13-14v
i would buy a lawn tractor battery, but thats just me. i would try a new battery before saying its a power drain
Thread Thread Starter Forum Replies Last Post
02 sportsman loosing charge Ronbo6270 Polaris 3 08-07-2015 12:54 AM
2007 kawasaki bayou 250 NEED HELP Sjrpp Kawasaki 3 07-08-2015 10:00 PM
Kawasaki bayou 250 NEED HELP Sjrpp General Chat 0 07-05-2015 10:26 PM
2007 kawasaki bayou 250 Sjrpp General Chat 0 07-05-2015 10:23 PM
2007 kawasaki bayou NEED HELP Sjrpp Other ATV Topics 0 07-05-2015 10:04 PM
Tags
2007 , 2008 , 420 , atv , batteries , battery , charging , check , drain , draining , drains , honda , rancher , viper , winches
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
