Rancher 420 in/out 4 wheel
Old 03-10-2009, 04:35 PM
trailbuzzer's Avatar
Default Rancher 420 in/out 4 wheel
I heard another say that to remove from 4 wheel, they had to back up about 15 feet after selecting the shifter to 2 wheel. Does that sound correct?
Old 03-10-2009, 05:11 PM
rimfire22's Avatar
No. just pull lever toward rider for 2wd light goes off you can keep
going forward. not like unlocking the hubs on a pick-up where after you
shift you drive backwards.
2008 rancher420fm
2004 dakota 4x4
Old 03-11-2009, 07:53 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The owner's manual isn't really clear on whether you need to stop to go in or out of 4wd, but I will always stop unless it is an emergency and I need to get into 4wd really quick. It seems like the quad needs to move a couple feet before the 4wd light will go out....but needing to back up...no.
Old 03-11-2009, 08:12 AM
Reconranger
I buried my operators manual out of reach, but I recall reading about this, and that it wasn't clear to me what one could or couldnt do, and what to expect from the lockin/lockout either.
Old 03-11-2009, 10:12 PM
mrk874's Avatar
I don't remember anything specific in the manual either, but the dealer did say to me when I bought my Rancher that you should come to a stop and put the machine in Neutral before moving the lever. I've been doing this and the green LED that indicates 4x4 always goes on or off within a foot of forward movement or so.
Has anyone else heard this? Recon - do you put it in neutral before shifting?
Old 03-11-2009, 11:47 PM
Amuro's Avatar
I don't put it in neutral.
Old 03-12-2009, 11:08 AM
AMuro
Then you just come to a full stop in 1st gear?
Old 03-12-2009, 11:57 AM
Amuro's Avatar
you can keep it in gear, come to a full stop and take it out of 4x4 or put it in 4x4. Some times I don't come to a full stop and take it out of 4x4 at very low speeds.
Old 03-21-2009, 09:48 AM
oxfordnative's Avatar
My manuel says don't remove your hand from the handlebars while moving, so it would be impossible to shift it on the go. My dealer said under 3 mph.
Old 03-21-2009, 12:14 PM
ugeesta1's Avatar
I've shifetd in and out of 4wd while moving at slow speeds all the time. Never heard any grinding or felt and jolts doing this. I do agree to check what's in front of you before taking your hand off the handlebars.
Quick Reply: Rancher 420 in/out 4 wheel
