250X 1st gear
Old 06-23-2009, 10:32 AM
mud99's Avatar
Default 250X 1st gear
How hard is it replace 1st gear and a new clutch? Well clutch is no problem but never done a gear what do you have to do.
Old 06-23-2009, 11:08 AM
budedm's Avatar
I've done a clutch on mine and you're right, no problem. Never did a gear but I think it's pretty involved.
Old 06-23-2009, 08:13 PM
91Warrior357's Avatar
to replace a gear you have to remove the engine...split the cases and then ofcourse take the gear off, and install a new one...so you will be needing new gaskets and factory suzuki gasket sealant, i just use Yamabond on ever thing stuff works great.
Old 06-24-2009, 06:00 AM
HondaMechanic's Avatar
C1 (countershaft 1st gear) is a replacable gear .. M1 (mainshaft 1st gear) is machined into the transmission mainshaft and is not replaceable , if it is bad the mainshaft has to be replaced , any shift forks worn should be replaced... You will need gasket kit A & B also ...
lonerider856
10-13-2023 03:45 PM
patrick.oc123
09-16-2015 03:45 AM
patrick.oc123
09-15-2015 02:45 PM
bigbear350quad
09-11-2015 12:40 PM
awer1968
09-08-2015 11:02 AM
Quick Reply: 250X 1st gear
