94 honda 300 4trax
Old 08-22-2009, 05:29 PM
ekimdoog's Avatar
Default 94 honda 300 4trax
new to atv's....just bought this 94 300 from a co-worker for $1000.
seems to be in good shape..but no e-start...gotta kick it, that's OK.
anything I should be aware of? typical things to watch for?
just plan to use on my 10 acres for utility stuff....haul small trailer, box scaper on driveway....etc....
thanks for any tips, mike
Old 08-22-2009, 05:38 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I would say you paid to much, even if it is in good condition. I could get a Rancher that is 10 years newer for that money. You can expect a few things to go wrong just based on its age alone. The front diff is an "open" design, which isn't so great.
They do have a reputation for being bulletproof, so that is in your favor. Change the engine oil at a reasonable interval....same with the differentials. Keep the air filter clean and oiled, and adjust that valves now and then and you should be good. Get a Warn 424 if you want to turn it into a selectable 2wd/4wd.
Old 08-22-2009, 11:50 PM
Malachi's Avatar
recon, where can you get 04 ranchers for $1k? I'll buy 2 of them!
Cheapest 200- ranchers I've seen have been about $1700 for beat to hell or blown engines. And I'm always looking for deals.
Old 08-24-2009, 12:34 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
That's not a bad price at all if it's in good condition.
I have a '95 300 Fourtrax 2wd that I bought new. It has been the definition of "reliable" and has been a work horse on my 430 acre ranch since it was purchased. The only complaint I have ever had about it is that it has drum brakes. If you don't submerge the brakes you should have no problem, but if you immerse them in mud/water, the seals will probably be worn to where they will let water into the housings and it will corrode everything inside. FYI, the Rancher was no better in that regard, having drum brakes or disc/drum combinations for the first several years of production.
You didn't say whether it was 2wd or 4x4, but recon was right about the Warn 424 if you want to have it turn worth a damn.
I would also do what I could to get the electric start working again if possible
Old 08-24-2009, 02:33 PM
ekimdoog's Avatar
Default 4trx
This machine has been used very little, very clean.
4 new tires, winch is a year old. It's 4WD.
No click from the atarter at all, matbe the relay/selonoid?
Anybody have some good troubleshooting tips on the E start?
What's a Warn 424? As mentioned .....new to 4 wheelers
Thanks much, Mike
Old 08-25-2009, 09:58 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
A 424 is a kit from Warn (no longer in production) that replaces your front drive shaft with a split shaft & gearbox- you mount a "selector ****" on your fender that allows you to disengage the 4x4 and spin only the rear live axle. This redirects 100% of the hp to the rear axle and frees up your front end for better handling in tight trails. I have one on my 99 TRX300fw. They are not easy to find, and are no longer in production by Warn.
Also- I don't know where reconranger is finding any decent 2004 4x4 atv's for only $1k- but in any case, you paid an appropriate price- I've seen '94 basket cases for less, and mint ones for more. Any decent shape 4x4 atv is worth $1k!
I would fix that electric start tho- no fun trying to kick over a stalled atv in a deep puddle or on a steep hill!
I posted the service manual at this link:
https://share.acrobat.com/adc/docume...5-5f1b0c807416
it might help you discover the issue with your starter-
wendal
10-31-2017 03:31 AM
rgjackson
09-17-2015 11:21 AM
wendal
09-15-2015 01:50 PM
wendal
09-15-2015 01:48 PM
Jason Campbell
09-07-2015 02:25 PM
Quick Reply: 94 honda 300 4trax
