86 honda trx 350 no spark?
Trx 350
I am having the same problem. I have a Manual and I have run through everything I can think of, I have checked the oil sensor and wiring. I was going to order the starting coil this week. Mine does not spark either. I got it to spark last weekend but when it died I have not had a spark since. Have you come up with anything since your last post?
Spark
I believe the Manual states a resistance of a maximum of 10 ohms accross the starting coil. I am picking up 13. I was going to order a new coil this week but then read the earlier post from the gentleman that installed a new one and still has no spark. I did the light meter test on the controller before the coil and got a light so I am getting power up to that point.
Hi folks, I'm in the same predicament, no spark. Fuel pump, fuel cutoff relay and 3 CDI units have been tried, no spark. I did the measurements and found a resistance of 1634 ohms across the exciter coil and ground. According to the chart shown in this thread, it should be 50-200 ohms. Also, I could not check the ignition switch as there is no blue/white wire on the CDI terminals. However, when the switch is on, the green neutral light comes on, the oil light sometimes is on, but not all times. I can't hear the fuel pump coming on when I turn the ignition, but when wired directly, the fuel pump works and it looks new. any suggestions?
CRamshaw777
07-18-2015 05:46 PM
