92' TRX300FW Rear End
Old 12-10-2009, 12:06 PM
augmont's Avatar
Default 92' TRX300FW Rear End
Newbie here - My immediate and extended family are starting to get into quads and here on the farm we have a couple of oldies that need lots of work.
We have a 92' TRX300FW that the rear axle went bad and in the process my father in-law broke the gear case. In looking for a used complete rear end I came across a 00' TRX400FW rear end and wanted to know if was compatible.
Your help is appreciated.
Old 12-10-2009, 12:48 PM
79hugger's Avatar
Hi,they are different and don't think it will work.Any 88 up TRX-300 Fourtrax differential will work 2 or 4wd.Check Ebay for some deals,there are usually a few listed most of the time.I shop at discounthondaparts.com quite often and they have micro-fisch breakdowns on parts for each year and you can compare models
Old 12-13-2009, 09:17 AM
augmont's Avatar
OK.........thanks. I found a rear end on ebay so hopefully things will work out.
Chasso
2) Chassis problems..
09-19-2015 03:06 AM
bmark0610
ATC 3-Wheelers
09-07-2015 07:57 PM
bmark0610
ATC 3-Wheelers
09-07-2015 07:48 PM
Quick Reply: 92' TRX300FW Rear End
