300ex having starting problems...NEUTRAL SAFETY SWITCH?? WIRING??
300ex won't start no lights or nothing.
Had to replace the key switch (2 wire switch) on my 06 300ex. It was running when I twisted the wires together at the key switch but when I had to take the headlight off to access the male and female plug I no longer had power what so ever. But If I hook jumper cables from another battery to the negative post on the bike and then clam the positive to the key switch wires itll fire up but the reverse light comes on while its in neautral. Any help would be greatly appreciated.
300ex not starting
I recently bought a older mid nineties 300ex. runs great but won't start or do anything with electric start. always have to jump solenoid. first i thought it was solenoid so i replaced it with new one. thats not it. the lights or nuetral light doesnt even come on and doesn't mke any sound when trying to start by button. i traced back to check the fuse and fuse is good then noticed one of the 2 wires coming from the fuse is cut and not hooked to anything....so would this have anything to do with it nt starting or nuetral light comin on when not running??? and if so, where does the wire need to be hooked to when i get another one spliced to it..
any help would be great. i'm totally lost..... thanks
#15
Hey need help with my honda 330 ex
[QUOTE=papa hogg scoot hey i need help with my honda 330 ex I installed a 330 big bore kit and a stage 1 hot cam now when i go to start it it just turns over trying to start but it doesn’t when try to start it black smoke come out the exhaust what could it be?
