HELP:'03 400ex Carb Leaking Out Bowl Drain Tube
The hose is a drain/over flow tube on the carb bowl. If it's pouring out of the bowl probably a float needle(item#21) sticking or worn. You can remove the carb and clean it,but since you have it apart best to just install a rebuild kit. Item # 36 on the parts break down. Dirt Cheap Honda & Arctic Cat OEM Parts & Accessories – Cycle Parts Outlet
Plus carb kits are available on ebay,etc.http://www.ebay.com/itm/Carb-Carburetor-Repair-Kit-Honda-TRX400EX-1999-2000-2001-2002-2003-2004-/171447431897?pt=Motors_ATV_Parts_Accessories&hash=item27eb1032d9&vxp=mtr
