How to restore faded plastics?
I have used boiled linseed oil and paint thinner, toothpaste, steel wool, wd 40, turtle wax, starting fluid, I mostly used this stuff in just little spots. The only thing I have found to work is a heat gun, but I don't like how it makes my plastic hard and brittle like.
So my question, is there anything else that might work?
Sanding and buffing can make the plastic look like new, but man is it a job. Depending on how bad it is, you can start with 220 grit and go up. If it is not too bad (just faded) you can probably start with 600 grit or even finer. Finish with 1000 or 1200 grit. Then it is ready for buffing with a polishing compound. I use a wool pad and a low rpm polisher. Take your time and be careful not to get the surface too hot. Like I said, it is a pain, but they will look like new.
Sorry it took so long to get these posted. The red tank is from my 85 ATC250r. It was badly oxidized. The black fender are from my TRX700xx. They were scuffed up and scratched. As you can see, they are still a bit dull and need another buffing, but I am satisfied with the way they are. I really wished I had taken before and after pictures.
