New machine
That Pioneer 500 in that pic looks pretty sharp. I'm sure you could simply bolt a toolbox on the rack and then you'd have lockable and weatherproof storage. That's probably what a lot of Pioneer 500 owners will do. The netting looks kind of silly though but I guess it keeps you from getting slapped in the face by a tree branch. I'd probably just take it off myself. I'm sure someone makes some bigger doors you could get instead.
I actually like the stock doors and nets that the pioneer comes with. I think all utvs should utilize this door/net combo. Extremely simple yet easy to operate.
According to these two sites the Honda SXS is still a 3 forward speed only like a Rincon and the Big Red http://www.atvreviewnetwork.com/enth...cleCode=441373. here is another site saying the same 2015 Honda Pioneer 700 Reviews, Prices, and Specs.
#15
#16
yea all the japanese SxSs are geared lower to accomodate the extra weight. Even the new yamaha wolverine Rspec only goes 52-53mph.
The thing I like least about the old rhinos was how much throttle was needed to get the thing moving. Most of the lower powered CVT UTVs are like that and scream at low speeds. I haven't had the chance to run them side by side but this little pioneer actually feels like it accelerates faster than my neighbors rhino and has a much better throttle response. I think if you guys had the chance to test one out you'd be shocked by how peppy it feels in the low-mid rpm range. You don't have to take your foot off the gas to shift up so the engine stays in the heart of the powerband
#17
#19
I don't believe the CVT loses power more then a 5 speed thing. I did a little drag race with my 350 Grizzly and a 350 Rancher down a straight gravel road and both accerated and had the same top end.
I drag raced my 500 Sportsman with 500 Foreman down the same road and out accerated him and had a faster top speed as well. I know the Sportsman has a 7hp advantage but it also is 100lbs heaver and it the CVT not suppose to take that hp advantage away? In the real world no.
Here is a 500 4x4 shootout https://www.powersportsnetwork.com/e...ew.asp?code=85 and all the ATVs were cvt except the 500 Foreman and the foreman could only just out power the 450 Grizzly which at 421cc should really be put up against the 420 Rancher not the 500 Foreman.
#20
You don't have to believe it if you don't want to but it's pretty much common knowledge at this point. I don't think too many engineers would disagree. Yamahas wet clutch is actually the worst offender of all when it comes to parasitic loses but any 5 speed with a clutch/auto-clutch will lay down their HP more efficiently.
This thing certainly isn't fast, (I was reminded of this when I took out my 700xx) but the OHV engine mounted with the crank shaft running directly in line with the drive shaft in combination with this 5 speed makes great use of the power.
