Carb problems
Brandon, the best tool for carb tuning is a wideband O2. Sounds like a lot of rigamarole, but it's quite easy, once you have a way to monitor A/F ratio. One thing that also helped me tune both of my Arctic Cats was Dynojet stage 1 kits. Check eBay, sometimes you can find em cheap. Typically the PMS screw should be out 1-3 turns. Turning in makes it leaner at part throttle. You may just have some dirt in the starter/slow jet. I like the grooved needles in the Dynojet kits, really let you zoom in on correct A/F.
baseline for air/fuel mixture screw is 2.5 turns out from lightly seated...Turning it out richens, in leans. Need a lot more info:
1) is the motor stock
2) are the jets stock
3) is the airbox stock
4) is the needle seated properly
Have you read your plug? is it running rich or lean at cruising (sputtering) speeds?
When was the last time it was thoroughly cleaned?
The air/fuel screw is generally the fine tuning area...
93-350l
07-17-2016 04:15 AM
