Start ATC without recoil
If the atv is worth saving,it's worth getting the recoil.1985 atc 200s recoil | eBay Get it running and plenty of people still are looking for these old 3 wheelers if you want to sell it.
You may be able to tow start it. I don't like doing this as it puts strain on the transmission. Personally I would remove that star wheel thingy, and use the four bolts to fit a cup shape rope start pulley, adapted from one for a mower engine. Make sure you get one for the correct engine rotation. Best not to ride with this set up though, as a pulley rotating next to your left foot could be dangerous.
Ebay is the first place I look for parts, hard to beat.
A lot of the automatic clutch bikes can be push started. It's been a long time since I rode a 200s. UHaul used to rent those, man did they get a beating!
Decide which gear you want, 2nd is usually best to begin with. Once you have the gear selected, don't let off the shifter, hold your foot in the upward position in that gear. Get the bike moving, then when you're at the right speed, let go of the shifter. Engine should start rolling over.
Be careful, good luck!
