1996 300 4x4 odometer cable question
I just bought a 1996 300 4x4. There is a cable coming out of the left side of the engine for an odometer. The odometer is no longer there, just the cable.
My question is can I just cut off the cable to get it out of my way? Is there a better way to disconnect it from the engine without creating any other issues? The cable looks factory but how an odometer would mount on the dash does not.
Thanx
Thanx
I think that if you unscrew the cable from it's little drive box on the transfer gearbox, you don't get leaks. Those mechanical speedos never worked very well and are broken on most of the late 300s we service. Many have the speedo removed and the cable tucked under the front plastic. The speedo mount was a bit "wooly hat," an obvious afterthought from Honda.
