pipes for a 400ex
i am looking for a slip on and not sure what to get. can someone tell me where i can see different pipes on a dyno. any pipe suggestions may get me on the right track also. i am looking for more power throughout the entire power range. also where is the best or cheapest place to order from? thanks
Try ordering from www.atvaddiction.com talk to Lewis. He will give you a good deal. You can pretty much just pick whatever pipe you want and get the same results on the 400ex. My Yoshi pipe works great, but it's a bit more expensive than the White Bros.... I'd say for your money, I'd get the E-series, or Pro-Circuit. If you want titanium, like I did, you'll have to spend a little more cash.
Mine has a Pro Circuit T4...seems like a great pipe...good quality and nice finish too. Unfortunatly I can't say performance wise since I had never ridden the bike stock.
I can tell you that it sounds really cool...maybe be a bit loud though if you have greenies around that complain. However, I think you can adjust the pipe so it is quieter???
-Josh
-Josh
I ride the dunes in Oregon alot, and I don't think I've ever seen a 400ex with a Big Gun exhaust on it. I almost bought one for my bike, but due to a lack of information about them (from riders that owned them) I decided to stay away and get one that has more of a reputation. You just want good quality (for me that means sound output, corrosion resistance, decent power gains, and easy maintenance (repacking)) If you really want more bang for your buck, get a better carb for the bike, like an edelbrock quicksilver. I think that will be my next mod.
Honestly from the dyno tests I've seen you aren't going to get much out of a pipe but a bunch of noise. The average gain is .5 - 1.5 hp. At $200 min., it really is a bad investment. Chad is right, a carb would be a better investment. Even a K&N filter and rejet at $40 will give you more HP than a pipe. Now if you where going to go to a big bore or high compression piston or cam, then the exhaust is a must. But if you are going to keep it stock, don't even bother.
You will gain plenty of hp from a complete system. You only gain a little hp if you go with a slip-on. I run a WB Pro-meg system. After I installed it my bike was completely different. It had a lot more hp. I rode a friends with an edelbrock carb and a slip-on. I did notice a lot better throttle response, but it had less grunt. That showed me how much the stock headpipe restricts the engine. The pro-meg headpipe is at least a 1/4" bigger in diameter. This is just what I have learned from my own experiences. I say save up and get a complete exhaust system.
Well i wouldn't suggest a pipe for a 400. Its just gona make it annoying and really won't help that much. If you do decide its necessary get a white bros. They have some good stuff. Check it out on rockymountainatv.com. They have 2 different white bros pipes. One says 2-4 hp and the other 4-7. Good luck.
