SportTrax 90 Shifting Problem, HELP!
Greetings,
My son has a bad habit of stomping on his shifter in order to assure that it is in neutral before staring a jump run or some other antic. Now we can't get it to drop into neutral at all. It shifts fine 1-4 but won't go down into neutral. Could he have bent the forks in the shifter? How do I tell? Is there anything I could try before splitting the cases apart. Any help would be greatly appreciated. It is also still under warranty, should I try to get the dealer to fix it, even though I suspect it is operator error that caused the problem?
KimSJoh
14
07-18-2015 07:20 PM
