taking the choke off of 400EX?
I was just on another forum and everyone was talking about how taking the choke off would help with power. how would that help? plus if it would help would i get in trouble with starting it in the winter? i live in utah and it gets pretty d**n cold at nights in the winter. any advice would be appriciated!
2002 400EX
14 tooth sprocket
paddles
2002 400EX
14 tooth sprocket
paddles
thrshr doesn't know what he is talking about and no you don't need to send it to a shop. I did it to my 400ex and I liked it. I wouldn't do it to yours because where you live. I never have a problem starting, but I live in sunny San Diego. The choke is different on the 400 compared to other carbs,it blocksthe throat of the carb from letting air in. Even when the choke is not on it is in the way of letting in the maximum amount of air into your engine. So people remove the restriction for increased air flow. It helps, but I don't know how much. Downfall is not having a choke and you need a choke where you live.
Removing the choke is a great cheap mod as it restricts airflow in any situation stock or modified motors.
I live in MA where it gets damn cold in the winter and have had ZERO problems since this mod. You definitely need to up your pilot jet to a minimum for a 42 to account to the increased airflow. The 400ex are noted to be quite lean on the pilot jet and are generally tough starting in the cold. I am running a 42 pilot with no choke and it starts and idles fine, even in the dead of winter.
thrshr i dunno about your 400ex but every1 i've ever seen doesn't need the choke to start in the summer. if you reread my post you'll note how i said i wou;dn't do it to mine cuz i like to ride in the winter, obviousley he does too and he would see its not a good idea to do unless your just racing or live in a warm place all the time.
