Cant get the lugs off my 400ex rear rims!?!
I just got a 2 inch slice in a reare tire so i am going to try and dismount the tires and put on new ones myself. Thge problem is I cant even get the stupid lug bolts off! I have 2 off on one side but the other two are too tight and starting to become stripped so i decided to stop messing with them. I put WD-40 on them to soak and its still tight. The sockets I use with the extension is still too short to get inside the rear rim and turn it. What else can i do? Thanks!!!
I would buy a 6" extension in whatever drive size your ratchet is and use that since it would be used for many other jobs later. Better yet, get a torque wrench to use instead of a regular ratchet. Those wheel nuts don't require much torque anyway..for example on Yamahas the spec is just 32 fp. I'm amazed that you haven't already twisted off one or more wheel studs from the rims. I think you need to be prepared to replace some of the studs..not a big deal to do. And torque the nuts to spec after you do the tire switch
