cr250 cylinder on a trx250.
On newer CR cylinders, no. They are case reed inducted so you would have no intake on the cylinder to mount the reed cage like a TRX cylinder. Older CR cylinders may work, but would probably require some machine work either on the cylinder, the cases, or both. I know there are companies building motors with CR500 and Polaris 400 cylinders so it has to be possible and there probably is someone doing it, I just haven't seen it.
