Very very cheap way to make reverse easy on a 300ex.
If you are doing this just to make it easier to operate instead of removing the linkage to save weight try this. It will last much longer than tape and not look sh!++y either.
Just adjust the reverse lockout cable on the right side engine case. [towards the rear]. You can adjust it so that it stays engaged at all times.
When you do this, your way or the other way, be sure to be in neutral when you pull the lever up to prevent tranny damage.
hey here is his address. emptymug@webtv.net he sold his last one but he said he modifys the stock ones. he has pics of them that he can send you.
