Need Some Advice on Buying a Pipe For My 300EX
I need some advice on what to do. Who makes a good pipe for one of these things? Also, is it best to buy a complete pipe or just a slip on/end? Is this even worth doing? This thing needs more a$$, just not sure if you can even make one of these things half way fast. I've riden for several years (12-15) but just decided to do a few basic mods. It sucks just being able to barely out run a 700lbs Grizzly.
A complete pipe is the only way to go. As for coming on this forum and asking which pipe to buy you are only shooting in the dark. The only way to figure which pipe/set up is best for your bike to is to research on the net. You have to many people on this forum who rolled the dice and bought a pipe set-up and swear that this is the s%^t cause that is the only set up they know. This forum offers lots 'o' info on pipes of every sort. If you read enough on here you will know which is the way to go. Be careful when taking advice from a stranger when it is your $$$$$. Any set-upb is better than stock. Use the forums search engine and build your own.
bpegram84
07-22-2015 08:15 AM
