Pull behind mowers
Polaris has them available through their dealers. There is a smooth-cut type and a heavier field mower type for heavy grass, weeds, & brush up to an inch thick. Should hitch to any atv with a hitch & enough power/cooling capacity to handle them. I haven't used one, but my local dealer had one of each on hand & they seemed well built.
Farmr
Farmr
Greetings,
There have been some very good threads on this in the recent past. You might want to run a search to check them out (try several forums including Utility as well as this one). But a few basic things to keep in mind when looking at mowers:
First, check the hitch very carefully -- it has to fit, not "just be close enough." I bought an industrial strength flail mower (from Alamo) that came with a "universal" hitch. The only thing "universal" about it was that it offered a poor fit in all situations. I spent a couple of months tinkering with the set-up before having a regular ball-type hitch welded on.
Second, an ATV is not a tractor, it is not set up to maintain a continuous speed. While this doesn't eliminate it from field work, it does make it a bit more challenging -- particularly if you have a lot of hills.
Third, don't skimp on the mower. They all look good in the store, but they take a real beating out there in the field. Its amazing how many ruts and bumps you discover in a flat field once you start towing a mower through it.
In a similar sense, try to get big tires. Most of the machines I see have 12" tires and they bounce all over the place. I replaced mine with 18" go-cart tires and run them on low air pressure to smooth out the lumps.
Check out Northern Tool and Equipment -- they carry a number of ATV mowers. Cycle County also offers a couple (check out links from this site). I also liked the looks of the Rhino mowers.
And my tip of the week -- mount a pair of bicycle mirrors out on the front corners of your racks. This will help you keep track of what the mower is doing behind you. The alternative is to swing your head back and forth for hours at a time.
fordfaithful21
12-07-2015 05:52 PM
Cdenton
Technical and How-To Articles
09-09-2015 11:23 AM
