12V outlet?
amperage/power
The amperage or power is determined by the circuit that you connect the outlet to. If you connect the outlet to a 5 amp circuit, then you can get 5 amps (without blowing the fuse). Simple as that. If you connect it directly to the battery, then the currect would be limited by the amperage of the fuse that you have in line with the device.
John3
08-23-2003 01:11 AM
