Looking for other members to talk Terrapro
The following 2 users liked this post by The.Kid:
Hapcamp (10-30-2019),
Odis Fitch (01-19-2021)
Yamaha Terrapro Pics
I thought I'd better add some pictures just to show these rare beast exist. One is almost totally restored and one is in original condition.
BTW. Looking for a set of rear rims compatible. Rims I'm looking for must be offset about four or five inches so they don't hang out like a monster truck. Size of tires on it are 24X11-9.
I got both out on a sunny days and ran them a bit to keep the gas fresh in the carbs.
The RC-42 you see in the third pictures is a 42" brush cutter capable of cutting down brush about 3/4" in diameter. I also have a FM-48 lawn finish mower and a TC-38 Garden Tiller. Mounted on the front of the unrestored one pictured is a suitcase weight rack that is used with the garden tiller.
Made only one year in 1988. This is the ONLY ATV every made with a PTO shaft output to drive two point hitch attachments. Tractors have a three point hitch. -thekid-
I have just bought a Terrapro yesterday. It has the FM48 with it only.
Rear rims were modified, not sure why but they must be off something else. I did not know these had one-off wheels so that explains it.
I have a broken reverses lever. That is my issue. Thread from yesterday on it. https://atvconnection.com/forums/yam...rse-issue.html
Also have oil leak on left cover and could use a carb cleaning/governor. Pretty good shape overall.
I am in Olive Branch MS
Thanks
Brian
Thanks
Brian
Thanks
Brian
Thanks
Brian
The rims on the TP are unique pattern. You can find them also on eBay if you wanted to go back original. It seems to have caught on that there is a market for used parts on these special machines. I'm currently restoring my second one. Take care. -=the kid=-
The following users liked this post:
As long as the tire fits the rim the tire diameter can be slightly smaller or larger. I'd suggest not putting on any raptor type tires. Keep the tires shape similar to what's on it and you'll be fine.
