help!!
Old 06-22-2015, 07:41 PM
jonathongolden250's Avatar
Default help!!
Hey igot a honda recon that the lights will not work with out battery but use to
Old 06-22-2015, 10:12 PM
Jaster94's Avatar
And the issue is....? A fuse? What led to a failure?
Old 06-23-2015, 07:14 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Check out the Honda section here and post your question in that. You'll get a lot quicker response.
Good luck, hope it's running again soon.
Old 06-23-2015, 01:41 PM
Thanks for the quik responce and i found the problem it was a wire that has been cut
Old 06-23-2015, 03:24 PM
Welcome to the forums. Good you got it solved.
Old 06-23-2015, 04:36 PM
honda recon 250's Avatar
Yeah thanks
Fyi-im jonathongolden250 i had to make another acount
