2013 polaris ranger 400
Old 01-07-2016, 07:36 PM
patokalake64's Avatar
Default 2013 polaris ranger 400
Just had a bad incident with the ranger. went through lots of water and it bogged out. What do I do next?
Old 01-08-2016, 01:53 AM
Welcome to the forums. First off pull the plug cap and use compressed air to blow any moisture from the plug and cap area. Same for any electrical connectors. Pull them apart,dry out any moisture and use electrical grease. Check the air filter and air box for any water. If you suspect water in the engine,drain the oil and filter.
Old 01-08-2016, 06:40 AM
I had a compression test done last night and it was at 50. Do you think the rings are blown.
Old 01-08-2016, 06:47 AM
scootergptx's Avatar
Supersock
Hired Gun!
Old 01-08-2016, 08:13 AM
Compression is low like this because of the decompression device on the cam. Normal to have compression between 50-90 psi.
mikesjunk
01-03-2016 07:16 PM
lonerider856
10-29-2015 08:17 PM
Mac25
10-22-2015 09:16 AM
Quick Reply: 2013 polaris ranger 400
