New to this need some advice
Old 08-20-2016, 02:15 PM
stacymeyer4472's Avatar
Default New to this need some advice
Hello my name is Stacy I have a 2005 Honda foreman 500 4x4 es. The reason I need advice is because my four wheeler will not switch gears no more. I have replaced the box on the handle bar I have replaced the shift motor I have replaced the angle sensor and the control unit box and still will not switch gears. When. It hits the 4th and 5th gear it makes a clicking sound when trying to switch gears. Any advice on what's going on thanks in advance
Old 08-20-2016, 07:43 PM
hydrex's Avatar
Welcome to the forums. Not a Honda guy, sounds like a bit of over engineering. When a Manual shift Arctic Cat doesn't shift right, I've heard it's usually a bent shift fork. Try to download a service manual and parts manual, perhaps it will be more obvious. GL
Old 08-21-2016, 12:21 AM
greg74's Avatar
How old is your battery? It could be something as simple as not having a fully charged battery. It is an electric shift system so not having full voltage could cause it to not work properly. Its a bit of a long shot but its possible. Its more likely that something is bent in the shift mechanism.
Old 08-21-2016, 03:18 PM
Welcome, Stacy. Try posting in the Honda section to see what kinds of answers you can get to help out.
Old 08-23-2016, 10:17 PM
bengear90's Avatar
Howdy! It might have a code, search for code retrieval.
Pgmyr
04-29-2016 03:52 AM
steve1747
04-16-2016 01:39 AM
Boxrusso
03-03-2016 08:40 AM
kahoona
09-09-2000 01:27 PM
lovinhonda
01-25-2000 09:17 PM
Quick Reply: New to this need some advice
